Hi all I'm back here in the 6.0 forum again cause I just bought a used 07 250 EC long bed 4x4 with 110 k on the clock for my work truck. However the gear shift lever is a little loose and I was wondering how hard it is to tighten it back up? It looks like I have to take the key cylinder out.
Before taking anything apart lay on the floor under the dash, looking up the steering column. There are two Torx head bolts that often loosen. This will make the shift lever loose.
Yup, very common problem. The bolts are T30's and are on the back of the shifter tube.
Drop the column down. There are four bolts that hold it to the dash panel. Once it's down you can replace the bushings between the shift tube and the column. It's not a hard job at all.
So there isn't a bolt or screws that tighten it up where the lever (shifter arm) attaches? Thx mark
Yes there is. Lay on the floor under the dash, looking up the steering column. There are two Torx head bolts that often loosen. This will make the shift lever loose.
