Can someone tell me how to fix a fan speed switch?
Low and medium speeds are controlled by a resistor block inside the blower/heater housing. The airflow across them keeps them cool. Sounds like yours is burnt out.
As far as the cowl, it is a bunch of screws that hold it in. Pop the hood, remove the screws inside the engine compartment, then in front of the windshield there are more screws inside the slots of the cowl cover. Get them all out, remove the cowl and take a vacuum to it.
I would not bother to pull the cowl itself as the stuff will have gone down further than you can reach. Pull the blower motor and clean in there. If that isn't enough, pull the kick panels and then the panels you see there - assuming you don't have the kick-panel vents. That gets access to where the stuff goes.
JaysDaddy,
An additional little bit of information... my experience has been that if the blower motor squeals or turns slowly, the motor draws more current and then burns out the resistor pack. As mentioned previously by Stangrcr1, the intermediate speeds are controlled by the resistor, but high speed is a direct 12 volts.
What I am suggesting is to be sure that you listen carefully after replacing the resistor. If the motor squeals or is slow to start when using the lower speeds, you might also want to replace the fan motor. Do as Gary suggested and remove the blower motor for cleaning. While it is out, spin the plastic squirrel cage fan and make sure it spins freely.
Oh yeah, it is always best to remove the negative cable from the battery to prevent shorts.
You can disassemble the motor to some extent to lube the bearings. Or, while it is out out some light oil on the shaft and work it in. However, that won't get the bearing that is inside the shell on the end of the shaft. For those it is possible to drill the outer case and drip some oil in. I have a motor that my father did that trick on several decades ago and it is still working fine.
Metro-Nut
10-21-2003 09:11 PM
