Sponsored by: Real Truck
FORD DEATH SHAKE!
Old Oct 20, 2013 | 08:39 PM
FM FordFan's Avatar
FM FordFan
FORD DEATH SHAKE!
I got it and I want to get rid of it. I have a 05 F250 with a 6.0L and 185,000 miles and I have owned it for about 14 months. It did it for the first time in February and has done it several time since then. I have had it in the shop twice and they cannot find anything wrong or out of spec. There is a video on youtube, if you have never seen a "death shake", just look up Ford F250 death shake. Any help in solving this problem will be greatly appreciated.
Old Oct 20, 2013 | 08:41 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
The easy band-aid is a dual steering stabilizer, like one from BDS, that puts two dampers directly onto the tie-rod and back to the axle tube.
The hard fix is to figure out what's really wrong. Tire air pressure is a really common one, but a bad steering box or loose links could all combine to cause it.
Scary though ain't it?
Old Oct 21, 2013 | 06:49 AM
HeavyAssault's Avatar
HeavyAssault
I had this type of issue but only at lower speeds. I used a duel stabilizer setup which stopped the side-to-side wander. Might be a good time to consider a small lift.
Old Oct 21, 2013 | 06:57 AM
I.B. Washincars's Avatar
I.B. Washincars
Why would you want to do that? Doesn't a lift exagerate the problem?
MC5C's Avatar
MC5C
Changing the track bar fixed mine. The rubber bushing at the chassis mount end gets soft. The bolt needs to be torqued to 400 ft lbs, not just hammered on with an air impact wrench.
Brian
Old Oct 21, 2013 | 07:04 AM
HeavyAssault
If the main issue is related to the steering linkage geometry then a lift would change those dimensions.
No one has found the true source of the wobble so it's only a suggestion, not meant to be the cure.
Old Oct 21, 2013 | 03:35 PM
speakerfritz's Avatar
speakerfritz
I had the problem...went with rancho dual steering stabilizers along with a set of rs9000 shocks in the front. death wobble gone.
Old Oct 21, 2013 | 03:37 PM
Jeff Watts's Avatar
Jeff Watts
Change every rubber bushing out for polyurethane. Make sure you install grease zerks. Trust me.
Old Oct 21, 2013 | 04:30 PM
BLKSVT's Avatar
BLKSVT
What he said^^^^
Old Oct 21, 2013 | 06:05 PM
Tofan's Avatar
Tofan
Holy hell. I just watched a video of this "Death Wobble" and I can say that before I watched that I would have thought it was a little bit of shaking, but god damn man. Like a tornado going through. Unfortunately as stated above, I have heard there is no "true" fix for it, only throwing parts at it to try to change whatever angle is causing that.
Old Oct 21, 2013 | 07:33 PM
redford's Avatar
redford
FTE Leadership Emeritus
Well, that just isn't true:
What WOBBLE?
Old Oct 22, 2013 | 09:42 PM
FM FordFan's Avatar
FM FordFan
Thanks guys, for all of the good advice. I am definitely going to look into solutions presented.
Old Oct 23, 2013 | 12:03 AM
Tofan's Avatar
Tofan
Redford,
Thank you for correcting me. I wasn't aware of the "What Wobble". But geez man, that is more then even just a death wobble. More like a alligator death roll. Hope you get it fixed Fm.
Old Oct 23, 2013 | 01:29 PM
GregsSD's Avatar
GregsSD
Check every steering joint in the front end!
All it takes is one loose or worn out joint to cause death wobble. Have someone in the truck turn the steering wheel back and forth while you look at every joint, it is fairly easy to spot which joint or joints have excess play in them.
When I used to run GM trucks with the IFS and 40" tires it was a nightmare because the tie rod ends would wear out quickly and cause a very violent "Death Wobble".
galena
2004 - 2008 F150
Apr 2, 2011 12:24 PM
thecondemned6
May 12, 2010 09:26 AM
hubbardk
May 14, 2008 09:45 AM
FireControlman
Sep 6, 2007 05:37 AM
AZSundevil
Jan 11, 2005 06:12 PM
