oil around crank case vent
This is a stock photo.
While trying to find the source of a small but annoying oil leak (3 inch spot on the ground after sitting overnite) , I noticed today that the 90 degree hose that is on top of the crank case vent, the side that connects to the long rectangular piece (not the side that is open to the air in the photo) was loose and there appeared to be oil coming out of it. The oil appeared to be coming from the clamp and leaking down to the 'warning' sticker. I say apperared because its not an actual leak...just oil residue..seepage.
Tightened up the clamp....but should there be any oil there to begin with? Seems like that's an air intake coming from the air filter. Where would the oil come from?
DDPJ
10-01-2015 10:56 PM
fairfield86f150
05-10-2007 02:01 PM
terp688
12-10-2003 08:45 PM
