2008 front wheel bearing
It's the same arrangement that Ford has used on a number of FWD cars over the years. I've had the same arrangement on 1st and 2nd Gen SHOs and on my Contour.
Yes, there's a snap ring. Use the shop press to push out the old hub then bearing assembly and to push the new bearing and the new hub back in. Don't push the center of the bearing out by accident when installing the hub.
I got mine done, wasn't to bad. I can't believe the rust, I have done 25 year old VW`s with less effort. I did clean, debur, antiseze, then freeze the bearing, the heat the housing to about 200* ,and used to old resized, outer bearing to tap the new bearing in. Took a while to get the wheel sender out, without damage. Thanks for the replies, Artie
1999-F150
06-03-2018 06:43 PM
