Are you sure about that? Thats a 34.5" tall tire. I had to do a 2" leveling kit to fit roughly the same size Nitto Terra Grappler. I'm saying you need a 2" LK. Final answer
315/70/17 is the stock Raptor tire size. Will it fit? Yes, will it rub? Likely if you're not near factory offset with whatever wheels you have currently, or what you're planning for. The height/overall diameter isn't so much the issue as is the width.
