2002 F250 CCLB Build
#121
#122
I see a lot of $$$ going to the body shop... I want to get my clear fixed on my hood, this bed side problem fixed, and I found something that warrants further investigation on the roof.
I just can't figure out how the water got in there... all the metal feels solid......
Thanks for the input Matt!
#123
#124
I just got back from the body shop. They are going to pull a quote together for me. I am going to see about getting the hood repainted, fixing the quarter panel, and fixing two rusting spots on the roof. The more I think about it, I may just learn to do body work... I know its going to be pricey. The hood needs sanded and repainted. I don't even think there are more than 2 or 3 small rock dents to fix. I can handle that. As for the bed, I am think of pulling it off in my buddies garage and getting out the chassis saver and hitting all the spots that Ziebart missed. Hopefully I can save it before its too late...
I was really surprised by the roof. One spot is on a groove channel on the roof and the other is near by in a channel. I've never seen anything quite that random. Anyway, should just be some sanding, putty, and paint. No big deal. It doesn't have to be perfect because no one ever sees it. I just don't want water coming through the headliner....
#125
I have similar random rust spots on my roof, I lightly saved as hit it with 2 coats of the duplicolor oem match using a toothpick. Has held up for the better part of 2 years now. Only other rust I have is the wheel wells which was "repaired" before I got it. Depending on how bad your rust is doing what I did may work out. Ive patched other scratches all over the truck. Its not worth having them professionally repaired because its a daily driven truck. Anything smaller then a dime I do. Bigger then that I may defer to the pros
#126
#127
#128
It is a huge money saver. I did my first bodywork on my Ranger. I took off the front fenders and replaced them with an unrusted, undented, paint matched set
#129
So here is the bubble. I poked it a worked all the water out. It was completely rust free. I checked in the fenderwell and couldn't find any rust either I sealed it with some touch up paint.
These are the roof rust spots.
I am going to touch up these spots up.
This is the driver's side rear door. I touched up the paint. I am going to clear it on the next nice day.
And I found this today too. Passengers side rear wheel arch bottom. I am going to pull the mud flap, remove the flaked paint and touch it up.
I bought a Duplicolor touch up pen from Advance for the blue. I take some picture of the completed touch ups. I think it is a pretty good match. The Duplicolor touchup pens have color matched pen tip and blush and in the bottom, they have the clear coat. For $15, I am pleased. I need to get the silver one still. I didn't notice I needed it until I got home.
On another note, I got the transfercase back together and in the Ranger. I picked up new seals for my front axle. Hopefully I will have it back on the road by the weekend
#130
Sold some parts this past week. So I bought some new ones
Picked up 4 Monroe shocks and 2 24" wiper blades from Advance Auto for $135. But.... there is a $30 rebate on the shocks through Monroe... so in the end, $105
Wiper blade comparison:
I disassembled the front when I got home from work. I am taking the rotors to get cut tomorrow morning. No more vibration...
Everything came apart pretty easy with the exception of smashing one finger with a hammer and I dropped a caliper bracket on another...
The pair:
Rotors came right off and are in nice shape.
While I have the front apart, I am going to grease the unit bearings, ball joints, and tie rod ends. I soaked the ABS sensors in OB Blaster tonight. Hopefully I do not encounter any problems in diassembly.
On another note, I picked up a new 15x8 wheel tonight for $20 and a 2 mile drive out of my way from work. This means I can finally get my extra tires for the Ranger mounted
I'll post a few more photos tomorrow after everything is installed.
The pair:
#132
As soon as I order the harnesses... whenever that will be. I tend to buy things and hold onto them a while. I've had the daylighters on the shelf since 2007 or so lol. I've had the 05 headlights for almost 2 years now lol. I also have an oil pressure gauge to connect in the Ranger and some Dixie horns to install that I've had for more than a year.
I am going to restore the lights on the truck first. I want to clean them up so I can sell them when I put the new ones on and recover some of the investment lol.
After the new headlights, I think I am going to change the cab markers and 3rd brake light. I have a little something in mind for those...
But before I do any of that, I need to change tranny fluid and replace the carrier bearing.
#134
Wizkid- Didnt order the harness through riff raff with the Grease fitting?
I know the feeling on parts hoarding, its called procrastination or just projects getting in the way. I think the truck is the one that pushes me sooner where some projects I dont want to mess up. I have some 5" lights for the bumper just have not removed it to install, and will also require some trimming.
#135
My GF actually made me clean my room a few weeks ago...and she doesn't even live with me lol, I had a dashboard, 4 rims, and tons of old truck parts in it lol. I'm a big parts hoarder, just haven't gotten around to putting them up on Ebay yet lol. Every few weeks they get closer and closer to an organized pile.
Wiz- your front springs look really flat, does that have a plow prep package? just curious mine are identical.
