I found my vapor lock issue!
So I had yesterday off (today too for that matter) & was cruising around in the brass monkey & thought it would be fun to go in for an oil change at the local jiffy spot.
I had a great time hanging with the guys there talking about the truck.
They let me climb into the pit & take a good look at the belly of my truck!
In the parade about 2 weeks back the truck performed almost perfectly, but after an hour of idle speed pulling a float she died. Started up again but then died. Luckily it was at the very very end of the parade when we were pulling back into the parking lot.
So thanks to the jiffy shop guys I was able to get this cool picture.
Sorry its sideways.
I'll give you 3 guesses what that silver canister is right next to the exhaust pipe!!
I think the quickest & easiest way to fix this is to get a roll of muffler wrap & put a couple layers of asbestos between my exhaust & my fuel line!
I'm looking for an exhaust guy who will re-route the exhaust too. I have TONS of room under the truck & the exhaust takes up it ALL.
Oh by the way - I ordered the alternator bracket off of ebay. Should be here in a week or so.
Sorry its sideways.
Wrap gets very hot (I have it on my motorcycle exhaust)and I don't think it would fix the problem. Best fix I think would be to move the filter. Otherwise put a sheet metal shield over it on the frame so there is air flow behind it. You can even use a self adhesive insulator fiber (Summit Racing sells it cheap, I use it on my leather bags over my bike exhaust) and that would also help keep the heat away.
That's the ticket! It's radiant heat from the exhaust, and shiny metal reflects that. Nothing fancy needed, might want to go to the boneyard and find a piece of factory heat shield that is aluminized or at least galvanized -- shiny.
Yes, go to your friendly DIY store or salvage yard and buy a piece of 1/16" to 1/8" aluminum sheet or angle about 6x12 (sheet) or 2 x 4 x 12 (angle). bend the sheet into a 2x4x12 L shape, slip the 2" leg inside the lower frame flange centered on the filter and bolt to the frame making sure the filter is not touching the aluminum, you want air space around it and air to be able to pass the length of the shield. That should solve your heat problem. Don't wrap the pipe, just makes it a larger radiator.
Stainless isn't as good a heat conductor as aluminum, but should work as above if you leave 1/2" air space between it and the filter.
Actually the best thing would be to make a shield that hose-clamps onto the exhaust pipe with a 1/2" air gap. Look at the heat shields on motorcycle exhausts, they only have a 1/4" air gap and you can lay skin against them (for a while).
muscle66
01-07-2007 09:47 AM
