Late model 2003 7.3 vs 99 to 02 Turbo Failures
Was there a turbo change on the late model 7.3 motors? My brother is looking at a 2003 7.3 F550 and they are saying it has had 2 turbo failures in less than 100,000 miles.
The current owner is telling him it uses a turbo that is similar to the 6.0 motor and not like the 99-02 models.
Does anyone have any info on differences with these late model motors?
Thanks!
Thanks!
Stewart
Lube
It should be getting lubricated just fine at idle. Just all those hours add up, there are only X number of rotations any mechanical part can make before it fails.
Another possibility is if it has the factory air box, they are prone to being broken or not sealed up properly, the turbos may be getting dusted and worn from that as well, especially in a very dusty environment as comes with construction typically.
As mentioned, bad environment conditions such as dust and dirt and a leaky/cracked air filter box can ruin a turbo. Plus being a construction fleet vehicle, it probably wasn't grandma driven.
rustyolred27
12-06-2011 07:17 PM
