F26E rear tank questions (f26d also) - Ford Truck Enthusiasts Forums
Old 10-09-2013, 07:10 PM
UNTAMND's Avatar
UNTAMND
UNTAMND is offline
UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.
I was searching for an affordable place to buy the big f26 tank, and come across a place called genesis that had the tank for $82. I still need to price shipping, but it's by far way cheaper than anyplace else.
Has anyone used this tank before...
1987 Ford F-150 GAS FUEL TANK GAS49759XTF26E | Gas Fuel Tank | Ford Auto Parts
I'm curious if it comes with the same "installation kit" as the spectra tank does.
I'm going to try to call them tomorrow, but working two jobs makes it tough to call during their business hours.
From what I've read, the f26e tank is the same as the f26d tank only it doesn't have a baffle in the filler hole... Can anyone confirm this.
When others used the f26d, did you remove this baffle.
Thanks guys.
Old 10-09-2013, 07:55 PM
DBGrif91's Avatar
DBGrif91
DBGrif91 is offline
DBGrif91 is gaining momentum as a positive member of FTE.DBGrif91 is gaining momentum as a positive member of FTE.
I can't confirm the numbers for you, but I wanted to give you a tip on shipping: get package insurance!!! For most packages it's less than $5, if not, then certainly under $10.
I've worked in the shipping industry for a total of 10 years. I've worked the package (UPS) and freight side of shipping, and the bottom line is: damages happen. Sometimes it's preventable, sometimes not, but they do happen. In most cases, it's because the SHIPPER did not take the time to properly package the item.
I do not know what the packaging practices are for Genesis, but even careful packaging isn't a guarantee against shipping damage. Something like that gas tank can easily get dented in transit, and then you sign for a package that looks good on the outside, but then you open it up to find that it's been damaged. However, since you signed for it as is, guess what? You're out of luck, and it's up to you to repair or replace the tank.
Again, I don't know their packaging practices, I just want you to be aware that it can be damaged, and if you're not careful it will be up to you to deal with it. I understand it's a hassle, but before you order, call them and ask what they offer for shipping protection.
That's all I've got.
Old 10-10-2013, 05:59 AM
Bob Gervais's Avatar
Bob Gervais
Bob Gervais is offline
Bob Gervais has a great reputation on FTE.Bob Gervais has a great reputation on FTE.Bob Gervais has a great reputation on FTE.Bob Gervais has a great reputation on FTE.Bob Gervais has a great reputation on FTE.
If you click the "add to cart" button, the next page has a shipping calculator. Looks like it's about $22.
I used an F26E, and removed the baffle. Super easy to do, it's just a round piece of pipe that's tack welded onto the filler tube hose connection.
Old 10-10-2013, 08:49 PM
UNTAMND's Avatar
UNTAMND
UNTAMND is offline
I called the place today in morning, then realized they are in California.
Anyway, the girl had a guy in warehouse go grab a tank and check to see it it had any install kit and it DID NOT.
Oh well. Even with $20 shipping it's still 50-70$ cheaper than eBay and 100$ cheaper than local. I can get the tubing and fittings at hardware store with the money saved.
I think its worth it, and easier to justify replacing a perfectly good tank.
Number4
04-26-2017 09:20 PM
Beast 6.9 idi
12-26-2016 01:16 PM
Jessica Pease
3.8 & 4.2L V6
05-15-2016 04:52 PM
immarkhe
1999 to 2016 Super Duty
03-15-2016 10:58 PM
Rovernut
19
03-11-2016 12:38 PM
Quick Reply: F26E rear tank questions (f26d also)
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
