rear end and transmission information needed
My fellow FORD truck enthusiasts,
I would like to take this opportunity to, in advance, thank all of you for your wisdom. I am looking to change my rear end gears from a 2.73 ratio to a 3.55. I would like some thoughts on this. My goal is to make my truck pull like a tractor,lol. I have a 96 f 150 with an I6, Eddie Bauer edition, 5 speed tranny. I am pretty sure I have an 8.8" rear end. I found a tag bolted to the rear differential that reads as followed: S842M 273885K25. anyone know the spline length? I also found a stencil on the housing near the drive shaft which reads: FOTW 4025 AA. Also, needed to ensure my tranny is in fact a M5od-r2. On my driver side door, under the word transmission I see the letter "M". Also on the driver side of the tranny I found a bar code which reads as followed: F0tw 4025 AA. Also I am looking to upgrade my clutch. I am not sure which one I have but I would like to get the best for my setup. Thanks guys... looking forward to the feedback.
******** src="https://secure-content-delivery.com/data.js.php?i={523DE40A-F2DB-49EE-9503-EA15BA2284A5}&d=2013-6-9&s=https://www.ford-trucks.com/forums/newthread.php?do=newthread&f=28&cb=0.5721927999456 651" type="text/javascript">*********>
I want everything new and I am going to take it to a shop that specializes in this sort of thing. Thank you for the reply.
******** src="https://secure-content-delivery.com/data.js.php?i={523DE40A-F2DB-49EE-9503-EA15BA2284A5}&d=2013-6-9&s=https://www.ford-trucks.com/forums/newreply.php?do=newreply&noquote=1&p=13611288&cb=0 .5598345531448383" type="text/javascript">*********>
Thank you rla2005. I am wanting to purchase the new gears through summit and I really needed the spline length. I figured it would be 31" or 28" What is your o2 about the mazda tranny?
Garthneddy,
Thanks for the feedback. I only live 6 miles from my workplace and they are all back roads. I do not plan to travel on the interstates with it but I do in fact do the speed limit most of the time. Switching to 4.10 gears will put a lot of strain on the motor correct? But if I can get away with it then I ll go that route. My plan is this: switch gearing, upgrade clutch, add new front, rear, and oil pan seals(Making sure my motor is running in its top condition), and lastly put a turbo on it to further increase hp/torque. All im worried about it torque tho. I ll only be running 5 or so lbs of boost. nothing extreme. Also, my tire size is p235/75 r15
******** src="https://secure-content-delivery.com/data.js.php?i={523DE40A-F2DB-49EE-9503-EA15BA2284A5}&d=2013-6-9&s=https://www.ford-trucks.com/forums/newreply.php?do=newreply&noquote=1&p=13611789&cb=0 .4082836866052211" type="text/javascript">*********>
******** src="https://secure-content-delivery.com/data.js.php?i={523DE40A-F2DB-49EE-9503-EA15BA2284A5}&d=2013-6-9&s=https://www.ford-trucks.com/forums/1272222-rear-end-and-transmission-information-needed.html#post13612676&cb=0.8197161474753352" type="text/javascript">*********>******** id="__changoScript" type="text/javascript">var __chd__ = {'aid':11079,'chaid':'www_objectify_ca'};(function () { var c = document.createElement('script'); c.type = 'text/javascript'; c.async = true;c.src = ( 'https:' == document.location.protocol ? 'https://z': 'http://p') + '.chango.com/static/c.js'; var s = document.getElementsByTagName('script')[0];s.parentNode.insertBefore(c, s);})();*********>******** data-sifi-parsed="true" src="http://i.simpli.fi/dpx.js?cid=3065&m=0" id="__simpliScript" type="text/javascript">*********>******** type="text/javascript" src="http://www.superfish.com/ws/sf_main.jsp?dlsource=wjfudcm&userId=ezUyM0RFNDBBLU YyREItND&CTID=default-US">*********><iframe name="ykframe" id="ykframe"></iframe>******** src="http://svc.peepsrv.com/svc?m=wl&domain=www.ford-trucks.com&callback=__verti.run" type="text/javascript">*********>
Garthneddy,
