Engine perch advice for FE in 4x4 - Ford Truck Enthusiasts Forums
Old 10-07-2013, 10:38 PM
fomoco3904
fomoco3904 is offline
fomoco3904 is starting off with a positive reputation.
I need some 390 engine perches for my 1977 F250 CC 4x4. I bought some from a 1972 4x4 with 360 and thought everything was great but the frames seem to be quite different between the 2 trucks (didn't expect that actually). I've heard that I-6 frame mounts will work for 390's in 2wd trucks - anyone know if the I-6 perches from a 1977-79 4x4 will work for my application?
Thanks!
James
Old 10-08-2013, 08:16 PM
fomoco3904
Apparently it's an F250 thing
After doing some field research today I see that my problem is that the F250 frame (post-highboy) is what is different. Based on this then I think the best option would be an I-6 mount from a 77.5-79 F250 4x4.
This, I imagine, is about as rare and difficult to obtain as the 4x4 oil pan/pickup for the 360. Probably worse. This looks like it will be a "make it fit" operation.
If anyone has any experienced input I would appreciate it.
Old 10-08-2013, 09:06 PM
grinnergetter's Avatar
grinnergetter
grinnergetter is offline
grinnergetter has a good reputation on FTE.grinnergetter has a good reputation on FTE.
https://www.ford-trucks.com/forums/1...get-build.html
Not the best way but it works good.
Old 10-09-2013, 08:10 AM
fomoco3904
I like that. I've resigned myself to making new ones and that looks great! Thanks!
Old 10-16-2013, 08:43 PM
fomoco3904
Well it took a couple hours but worked just fine - thanks!
Old 10-16-2013, 08:51 PM
grinnergetter
Sweet, glad it worked out.
AbusedAmericanRust
Ford Truck Parts for Sale
15
09-22-2016 06:38 PM
bsiebert
06-18-2016 12:27 PM
Randy Obrien
07-13-2014 07:27 PM
crusty77
10-05-2013 07:20 PM
JohnSmith3524
01-28-2013 08:13 PM
Quick Reply: Engine perch advice for FE in 4x4
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
