Family 56 rebuild thread.
As you all may or may not know I have a 56 that has been in the family for over 40 years. My step father bought it used in Mississippi, then moved to Arkansas with it, then gave it to me. I drove it for a few years and then gave it to our son. While our son had it it was hit in front of our house by a young driver.
We then parked it for almost 25 years. Since then our son took his life and my Step father died of Cancer. So the truck is back to me.
I spent the better part of a year trying to find someone to straighten the frame, even bought a different frame, but finally found a small body shop to straighten the frame. Once back I wire bushed the frame and gave it two coats of POR 15.
I then Cleaned up the old 272 and drove it around a bit.
While recording a video of the truck running it started to blow white smoke. Needless to say a head gasket gave way.
So I found a 292 +030 and rebuilt it with ECZ G heads, "B" 4 barrel intake and a Holley 470 CFM carb. I backed it up with a Flat-O C4 adapter and C4.
Installed the power train and added Toyota Power steering.
The following users liked this post:
Good progress!
Two questions:#1 do 56 cabs rust out there more so than the slant cabs?
#2 what kind or color of paint did you use for your exhaust manifolds and the crossover pipe? I don't like the color of mine. I used a high temp raw or natural mainfold paint. It looks too aluminum or silver to me. Almost the same color of the argent valve covers. I would like some contrast between the two.
Here's what I mean.
Here's what I mean.
[QUOTE=abe;16827828]Good progress!
I have two 53-55 Cabs with good roofs but there are a bunch of 56s that have rust in their roofs. All 53-56 Cabs have trouble with rust in their corners.
I used High Temp satin black engine paint on my entire exhaust system. I can't verify how well it holds up as I really haven't driven it yet.
It's for my suburban fuel tanks filler neck. I reinforced it with a 4" pipe but still may end up boxing the frame rail too. Read a lot on this mod but mine is very close to the rear spring shackle as you can see in the picture.
http://www.autopartswarehouse.com/sk...L/C670146.html
