The voltmeter shows 14 - 15 volts prox. The battery light will come on for up to 30 second or just flicker. Usually it jus flickers. It will be off for 30 - 60 minutes sometimes. When I turn the key on to start it, it comes on and then goes off when it starts.
There are two plug ins on the alternator and the single small one was loose and corroded. I cleaned both and sprayed contact cleaner on and the problem is fixed. Thank you again. Now I wonder if I am going to miss the flashing battery when I am driving, hmmm.....
