Driveline noise
Driveline noise
I have a driveline clicking noise I can't seem to pinpoint. I've got mile marker 35 spline hubs, lock right in the front, and twin stick 205. The noise is coming somewhere from the t case forward. It almost seems like my hubs aren't fully unlocking causing my lock right to click, But I don't know of that's it. When driving down the road the twin sticks vibrate, so that kind of seems like a transfer Case bearing.
Aside from the hubs this set up is about 4 years old, everything was rebuilt with new bearings and seals, and serviced frequently. There aren't any leaks, and the ujoints are all tight.
Any preliminary thoughts? I plan on trying to accurately diagnose it this weekend, but I figured if post here for some direction.
It is rattling through the twin shifters, but it's only hustled started, I can hold pressure on the shifters and it goes away. I'm using 3 thrust bearings between the shifters bolts and trans housing, to eliminate both slack between the sticks and eliminate excess friction. Ill pull the shaft this weekend.
Bronco Buddy
1978 - 1996 Big Bronco
12-16-2020 12:47 PM
Spyder3000gt
1999 to 2016 Super Duty
01-21-2012 01:41 PM
johniebomb
10-13-2008 03:32 PM
