Highboy front axle??????
Old Oct 4, 2013 | 03:09 PM
USMC0351fordtruckin's Avatar
USMC0351fordtruckin
Hey did highboys come with Dana 60 fronts. There is a highboy in the local scrapyard with auto hubs they said they'll sale it to me for scrap price
Old Oct 4, 2013 | 03:32 PM
montana_highboy's Avatar
montana_highboy
Very few did, but if they were ordered with a D60 front it was a low pinion D60, not the later (78/79) high pinion D60.
Old Oct 4, 2013 | 03:36 PM
USMC0351fordtruckin
Ok thanks. How can I tell if it is a 60 this truck has a '78 front end but I though '77 was the last year for the highboy? It had a divorced transfer case and it sits pretty high so I pretty sure it's a highboy. Did 60s have auto hubs ever
Old Oct 4, 2013 | 03:46 PM
montana_highboy
'77 is the last year for the highboy, as well as the low pinion axles, both D44HD and D60...
If the hubs look like these it's the earlier low pinion axle...
Old Oct 4, 2013 | 03:51 PM
USMC0351fordtruckin
No this truck does not have manual hubs it has a dombed end. It's leaf sprung with a differential so before you ask me yes it's a 4x4 haha
Old Oct 4, 2013 | 03:53 PM
ranger429's Avatar
ranger429
IT is called full time 4wd, not auto hubs.
I don't know if full time was an option in 77 and earlier, always thought 78 was the first year for that.
Look like these?
Old Oct 4, 2013 | 03:54 PM
montana_highboy
So it's full-time 4x4, gotcha.
Throw a wrench on the diff cover bolts...
D60 will be 9/16"
D44 will be 1/2"
Old Oct 4, 2013 | 03:59 PM
USMC0351fordtruckin
Ok. it has a shifter for the transfer case, is that still called full time. Were they DANA 60s that where full time, if not are they still worth anything?? Did trucks still get divorced transfer cases in '78 or did someone put that in?
Old Oct 4, 2013 | 04:03 PM
ranger429's Avatar
ranger429
Yes the full time still had a shifter handle, yes they used full time on the D60's and yes if it is a true 78-79 D60 they sell on average for around 1K.
No divorced T-case in 78.
Old Oct 4, 2013 | 04:06 PM
USMC0351fordtruckin
Did Dana 44s come full time as well???
Old Oct 4, 2013 | 04:08 PM
ranger429's Avatar
ranger429
Yes. The only way you are going to know the real identity of the axle is to go back there and check the cover bolts or the hub dimensions.
A D44 will be about 3 1/2" and a D60 will be a shade over 4".
Montana should be able to tell you whether or not full time was available on a pre 77 model.
Old Oct 4, 2013 | 04:12 PM
USMC0351fordtruckin
Ok thanks for all the help guys. I have another tread in the dent side section too if yins can help me with that too
Old Oct 4, 2013 | 04:13 PM
USMC0351fordtruckin
https://www.ford-trucks.com/forums/1...f-750-4x4.html
Old Oct 4, 2013 | 04:18 PM
montana_highboy
Highboys were available with both part-time and full-time 4x4...
After nearly four decades any axle could be under that truck...
You'll need to check it out to be certain, a 78/79 D60 would be a steal for scrap price.
Old Oct 5, 2013 | 12:51 AM
Jdeshler's Avatar
Jdeshler
D60 will be 9/16"
D44 will be 1/2"
That's good knowledge right there.. ill remember that one
51MHF5
Jul 7, 2013 02:39 PM
Stinky7-11
17
Nov 26, 2011 01:44 PM
Big billy C
Sep 20, 2009 10:18 PM
78 Ranger
Aug 15, 2006 06:16 PM
speedsauto
Aug 16, 2003 08:50 AM
