What seatbelts did a 1987 F800 have?
My 1987 F800 only has lap belts, Does not have shoulder belts and holes are plugged like they were from the factory.
Will be adding full belts to it ASAP, but was wondering if some would have came out with only lap belts.
I know when I was running over the road back then, Lots of trucks only has the lap belts. Just not sure on the fords.
Pete
Pete
There's a gazillion different pics, too many to post. If you get the parts catalog, go to Illustration Section 620 and start looking...
Non-retracting lap belts standard equipment, retracting lap belts optional, shoulder belts optional ... but only available with specific seats.
Not sure what parts catalog your talking about? But will try to look one up when I know for sure.
Pete
I have a scanner, so once the slide is placed in microfiche viewer, I can scan and post pics from it. But, process is much simpler with C/D.
Left (upper) & Right (lower):
Bill sorry I feel so dumb. I have the CD you were talking about. Don't like it as it does not have a directory that allows me to search for something or find it fast. But with you putting section 620 it was easy. Now if I could figure out how to copy and paste from it.
The last set is is what I need. So thinking I can go to the local junk yard and get a set to try.
Pete
PS forgot the directory in front works, but wish it had a search section. I Know were spoiled.
Pete
Bill
Would you happen to know what size and threads the water temp sensor for these 7.8's use? Need to replace the one at the Thermostat on mine. And it looks to be a normal 1/2" one. But have not taken it out to make sure yet. Would rather be able to get a replacement and swap them out fast without draining the fluid.
Rusty_S
10-21-2017 11:37 AM
jax72sportcustom
19
02-19-2012 02:36 PM
