84 ford f-150
Old 08-31-2013, 03:16 PM
waltharper's Avatar
waltharper
waltharper is offline
84 ford f-150
looking at a 84 ford f-150, 300 cuin and auto to buy
they say it has 94K on the clock......
What should i watch for?
Tempted to put the 300 and auto in my 62 f-100
Old 08-31-2013, 05:12 PM
fabmandelux's Avatar
fabmandelux
fabmandelux is offline
Afternoon Walt. 94K on a 300 six is not much depending on the maintenance he's done. Not much different checking things. Check the radiator fluid, check the oil and trans oil for burnt smell, color, etc.
The 300 would be a great engine/trans combo for your 62! Pull the smog crap off. Install a Offie 4 bbl manifold, 350 Holly, and a set of headers, amd BINGO! Plenty of pull power and 20+mpg!
It's what I've got in my 67 shortbed......
Old 08-31-2013, 06:43 PM
waltharper's Avatar
waltharper
What gear ratio do you have in your rear end?
Should the 84 have a computer and electonic ignition?
Old 08-31-2013, 07:04 PM
fabmandelux
I have no idea what the ratio is Walt.............But I can look when I go to the shop tomorrow.
An 84 will NOT have a computer, but will have Duraspark ign. It may have a "feedback" carb on it but it can be thrown in the junk and replaced with a different one.
Old 09-02-2013, 07:30 PM
Old93junk's Avatar
Old93junk
Old93junk is offline
Probably no feedback computer carb on a 300-6 1bbl, that went mostly to the 302s with the 2bbl 2150A feedback carb.
Old 09-09-2013, 05:02 PM
waltharper's Avatar
waltharper
I waited to long, it is gone but I am looking for 80 oit 85 as a donor vehicle.
If I change out the steering colum from a 65,do you think I could use the steering box from a 81-85 f-150 or get a toyota box?
85AustinTucker
Texas Chapter
02-03-2014 09:00 PM
DOC G
09-19-2012 09:33 PM
hoobatech
03-14-2009 09:05 PM
jeff8362000
18
11-20-2007 10:19 AM
4wheeltank
10-06-2005 08:50 AM
Quick Reply: 84 ford f-150
