what scanning equipment is available for do it yourself guys ?
Just bought a 2005 f250 superduty 6.0 4x4 lairat and the problems are stacking up! I can't find anyone with the correct scanning equipment for this truck in southern baja califonia except the dealers who are modern day robinhoods (65$ for a trans filter) who rarely get the job done right ! looking to buy whatever it takes to read every system on the truck i.e. trans... ! any ideas ?
I use a SNap-On Solus with V7.2
You can find this on Ebay or get an
Riffraff Diesel: AutoEnginuity Total Ford Enhanced Bundle
The people that have this seem to be very happy.
Sean
Sean
I didn't know what I would be happy with, so I decided to spend 20 to $25 on torque pro and see if it would do what I needed ...... Knowing it might not be enough. But it was cheap enough to not matter too much. So far, it's been enough. I may have to upgrade one day, but I'll wait till that time comes.
Scanner shopping
Im searching old threads trying to find a good scanner. The snap on Solus seems to be a good tool especially with the new software upgrades available.
It is a little out of my budget though. I looking at spending $1000 to $1500
I need to be able to diagnos my 06 6L PSD.
Cylinder contribution test, etc,
With the warrantee gone I need to be able to diagnos all engine problems.
Any suggestions are welcome
Thank You
Thank You
It's all dependent on your budget. I personally have a Panasonic Toughbook CF-19 ($250) with a Rotunda VCM module ($1500) and Ford IDS software (free download but $600 user license). It's not exactly the most economical setup but it is the same thing the dealer has. I got mine subsidized through work otherwise I never would have been able to afford it.
Beware there are a TON of fake VCM units on eBay. In fact I'd say most of them are fake Chinese knock offs. If you ONLY work on Ford, Mazda, Jaguar, and Land Rover I'd go for the IDS setup but for all around usability I'd look into one of the Snap-on models but they're fairly pricey too.
Yeah they're junk. I've read about them actually smoking and melting down. I guess the temptation to pay $300 vs. $1500 makes people take the risk but a $300 POS isn't really a good deal in the end...
They look almost identical however. It is very difficult to tell if its fake without calling Rotunda with the serial number.
If all you need to do is read codes that will work fine. In fact you can buy a simple pocket scanner for less than $50. If you need more diagnostic capabilities you'll have to step up to something a little more capable. It just depends what you need it to do and your personal skill level as far as diagnostics are concerned. You could have the best equipment available but if you aren't trained to use it, it's not going to do you much good.
Sean
Sean
