Drag link or pitman or both?
I gave my wife her 58 last week on our 25th wedding anniversary. She took it for a short drive and said " You'll have to fix this streering before I ever drive this again." I did an axle flip (front and back). I'm not sure what bump steer feels like but that may be the issue the truck has. I put new tie rods on and just got the front end alined. I also put on a new steering stabilizer. Stocks are new too. What do I need to do to the pitman arm or drag link to fix the problem?
Causes of loosy-goosy steering: Worn steering gearbox internal parts; draglink; right/left tie rod ends; kingpins.
Back then, it was commonplace to change the oil, filter and have vehicles lubed every 1000-2000 miles.
Today, many people have forgotten or are unaware that vehicles this old need to have the suspension lubed. Lube dries out, ball joints in draglink/tie rods ends wear, begin to flop around.
Spindles have top & bottom zerks to lube king pin bushings. When was the last time any of these parts were lubed?
Left (upper): Draglink (3304), Right (3A130) & Left (3A131) Tie Rods ends.
Right: King pins (3115) & bushings (3110), sold as B7C-3111-A King Pin Kit (1957/64 F100/250 2WD).
Cornelius
09-23-2003 03:22 PM
