Hellwig Install Cost?
Old Oct 2, 2013 | 07:40 AM
Limoguy's Avatar
Limoguy
Can anyone tell me an acceptable labor cost or shop hrs. to install the Hellwig sway bar? I need to make a decision. I'm past my mechanical prime (71 yrs. old) and may shop around for this. In my earliar years , there wasn't much I wouldn't tackle,but laying under the "Beast" for several hrs. isn't something I should try.
Old Oct 2, 2013 | 08:06 AM
LivingLarge's Avatar
LivingLarge
I had mine done at a local 4x4 shop a few years back for $75...
Old Oct 2, 2013 | 08:08 AM
jspence105's Avatar
jspence105
It should only take an hour or two, just look at the installation instructions online. The color photos make a huge difference in figuring out what to do. Call the grandkids and tell them to do it.
Old Oct 2, 2013 | 09:04 AM
Limoguy's Avatar
Limoguy
I called my shop who does most all my work and they quoted $72.
Old Oct 2, 2013 | 09:19 AM
LivingLarge
Sounds to me they may get a $3 tip
Old Oct 2, 2013 | 09:56 AM
Archion's Avatar
Archion
Veteran: Marine Corps
An hours labor should cover it. Took me just over an hour with no lift and a couple of beverages...
Old Oct 2, 2013 | 10:21 AM
LivingLarge
Very easy but I do understand the op, I'm 51 but with heart issues it's not worth doing yourself for $72 savings.
Old Oct 2, 2013 | 03:14 PM
mecdac's Avatar
mecdac
Not worth dying that is for sure.
Old Oct 2, 2013 | 08:01 PM
Limoguy's Avatar
Limoguy
Grandkids are 290 miles away. Good excuse to hook the TT to the X and go visit. I just got back Monday from a 4 day weekend visit.
Old Oct 3, 2013 | 02:33 AM
Apocalypse's Avatar
Apocalypse
Think I paid $85.
Old Oct 3, 2013 | 05:54 PM
Limoguy's Avatar
Limoguy
I was quoted installing an OEM sway bar for $72. The actual labor on the aftermarket Hellwig was more because of difficulties. It was 1.5 hrs.= $135.
Old Oct 3, 2013 | 06:34 PM
LivingLarge
I guess since I had it installed at a 4x4 shop, that's pretty much all they do. Tech did my Hellwig in under an hour, a week later installed my RAS in under an hour also. $75 each time.
Old Oct 30, 2013 | 02:43 PM
2006LJ's Avatar
2006LJ
Have you found improved performance with these after market rear sway bars for both towing and daily driving? I tow sporadically, but usually over 100 miles, and I considered putting one on my suburban, but never did.
Old Oct 30, 2013 | 02:52 PM
LivingLarge
YES, I just installed them on my 05' Yesterday and had them on my previous Ex. In my opinion there is nothing better without short of replacing your leaf springs than the RAS with a rear stabilizer for a stock spring Ex. Whether your empty or towing, you can't beat it for the money... No I do not work for RAS. RAS will give your EX what I refer to as a tightass rather than a sloppy one. Get both the Hellwig sway bar and ras together, you won't regret the purchase
Old Oct 30, 2013 | 04:54 PM
Limoguy's Avatar
Limoguy
The non-towing ride and handling is much improved. I haven't towed with it, but am expecting a positive improvement. I gained 1/2" in rear ht. and lost the same in front while unloaded.
