New Garage/Shop
#286
#287
#288
Jim, the feed will be through the front wall directly from the meter. Right now I have a temporary 50 amp RV feed (actually 2 50 amp legs for 100 amps @ 250 VAC) coming in through the back of the panel so I can power things like the door operators and lights the way they will be permanently.
Once I have set up the braces, then comes the real fun, mounting the doors, I want to do that before I close the wall in.
#290
The electric company isn't giving me a hard time, I need a wall for the meter base to mount on, then need to have the electrical inspector clear it for hookup.
As for the doors, I have my CM 3 ton chain hoist and another 1.5 ton wire come along, I plan on lifting each door in stages, one end to the other until they are in place. The reason I want to do them before the wall is closed in, I can be outside to put the bolts in rather than under them.
#292
Today I finished the wall bracing. I used some perforated angle so I could span a long area as the longer roof panels are 10' long from the end holes and I wanted at least that much. The left side I only went a little more than 10' as the next joint over is in-line with the walk-in door hinge side. Right side I went as far as I could since that covers the two tall king posts and most of the 8' door.
#295
#296
#297
Now that the wall is framed and braced, I hoisted and attached the 10' door. I still have some adjusting to do and am waiting for a delivery of some angle to replace the missing pieces. I also have to install the operator and adjust it, wire it and add the manual chain and clutch rope.
Here are the two items I raised it with, the first is a CM 3 ton hoist, the other is a no name 1000 lb come along.
#299
Gary, as to weight, I don't really know, I would guess probably 12-1500 lbs if not a bit more. BTW, you were correct in me not seeing your newest thread, I was working on the other door and continuing on the 10' high one. Here are today's pictures, I waited till it was somewhat dark and then plugged in the lights and took them. First is the 10' door and operator, second is the 8' door and operator.
