Why would this happen???
Sunday morning I started my truck and after a couple minutes of it running while I was loading my trap guns it started puking coolant out of my coolant tank, through the lid.
I turned the truck off, cracked the cap a little to bleed off pressure and then retightened and no issues. The puking put me about 3" below the minimum mark. The truck was cold when I started so there was no way it could have been overheating.
No. It actually didn't register for a little while and then the heater wouln't blow warm air for a while either, even though the water was hot.
Guess I need a new t-stat. Wonderful.
That is pretty easy to get to right? On top of the water pump (which is brand new) if I am not mistaken. Just never really paid attention that particular piece when I did the pump.
Yup. It's right there, front-and-center.
Watch for good O-ring sealing afterward, however, as some don't get it right the first time.
See: https://www.ford-trucks.com/forums/1...sing-leak.html
Pop
Pop
Received 3,692 Likes
on
Your truck is fine. Add more coolant and keep an eye on it until the "usage" tapers off and the heater works normally.
NO. I did not replace the t-stat when I replaced the pump. I replaced the T-stat last year because it was leaking. Then this spring the old pump blew one of the inner seal and blew coolant all over.
After the old engine blew I got a used motor and cleaned it up. I put the new pump on that and tossed the old pump since it was corroded.
As for short or long stem, I have no idea. whatever carquest sent when I gave them my vehicle specifics. Guess I will find out tomorrow when the new one gets here.
I stress that I don't yet think the OP is in orbit with either of these serious issues yet.
