99 V10 runs rough with 1/2 tank of gas - Page 2 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > 1999 to 2016 Super Duty
Reload this Page >
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 10-02-2013, 09:30 AM
dkf's Avatar
dkf
dkf is offline
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
I am now driving the truck with this intermitent problem that is worse with a low tank of gas and when the ambient temp is higher.
If you let the truck sit for a while after it starts to misfire. Does it miss less when you start it up and drive again?
Old 10-02-2013, 10:00 AM
tesserra
tesserra is offline
tesserra is starting off with a positive reputation.
No, only real consistent way to make better is fill up the tank.
Old 11-15-2013, 09:06 AM
tesserra
tesserra is offline
I took the truck to my local mechanic and he found the injector wire for the #1 cylinder was loose.
I am not sure how those symptoms pointed to that as the problem.
Truck runs great now thanks for the help.
Old 11-15-2013, 11:19 AM
phillips91
phillips91 is offline
phillips91 has much to be proud ofphillips91 has much to be proud ofphillips91 has much to be proud ofphillips91 has much to be proud ofphillips91 has much to be proud ofphillips91 has much to be proud ofphillips91 has much to be proud ofphillips91 has much to be proud ofphillips91 has much to be proud of
Originally Posted by dkf View Post
These trucks don't throw misfire codes very easy, thus I am not surprised you did not get any.
At 40k miles I had two cop and one plug go bad. I had to downshift and hold it wide open to climb a small hill at 35mph and it never threw a code. The dealer ran a scan and found which ones went bad.
McCloud853
03-24-2017 09:09 PM
mystangrock
02-22-2017 09:19 PM
jblueep
18
06-14-2016 06:01 PM
jzombakis
06-21-2012 10:31 AM
CriticalMass
52
04-10-2010 12:16 PM
Quick Reply: 99 V10 runs rough with 1/2 tank of gas
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
