Lost compression on No.8 cylinder
Turned out to be a lost bolt from prior work done. I've only owned the truck a few months and have not had any engine work done myself. However, the engine has a PowerMax Turbo, studs, gaskets, oil cooler, injectors etc. Looks like a negligent mechanic dropped this bolt and did not bother to check the intake manifold.
After a unknown period of time, the bolt found its way into the No.8 cylinder intake port and jammed open a intake valve. The valve bent and the valve seat was damaged. The top of the piston was lightly scored.
Needless to say, it was a crappy and expensive day. I would send photo's but can't remember how to do it.
Not as rare as you think. Same thing happened on my 72" 3/4 ton 390. The shop used a spinning basket type deal to clean the heads after a valve job. I'm not sure if a bolt worked its way in then or if I was sabotaged by a disgruntled boy friend.
lessons learned.
1. Check ports before buttoning up.
2. When your stealing someones Girl friend don't do a Valve Job at her house.
lessons learned.
lessons learned.
lessons learned.
Free floating bolts play hell on valves, pistons and cylinder walls
NOT me but I know of a guy that was rebuilding some thing on the top on the
engine and dropped a nut and could not find it. He found tit at first start
when the flame blew back up out of the carb. They stopped at that point
and went looking. It was between a valve and the seat. This guy was not the sharpest
tool in the shed. He later went on to fix a leaking head gasket with JB weld all
over the gasket and then stuck the head on.
Some times I think what havoc is he causing now.
Back to the topic.
How did the walls do ? Head damage only I hope.
Sean
Ranger Bob
11-06-2017 06:57 AM
svooom
06-30-2005 12:26 PM
