dustcover?
dustcover?
I have a 2003 F-150 4.6 4X4. I had a knocking sound that sounded like a rod knocking but was coming from the bellhousing. After some research, I found that it could be a cracked flexplate or bad torque converter. I bought and installed a new torque converter with no change. The flex plate didn't appear to have any damage but went ahead and replaced it with the same results. I actually started the engine by jumping the starter (with no transmission) and the sound was coming from the flexplate/dustcover. My question is do I need the dustcover? Or is it a bearing or something else inside the engine causing the flexplate to hit the dustcover?
