1975 F250 Driveshaft too short?
We have a 1975 F-250 RWD Auto with 390. I was going through everything when I noticed the rear section of the driveshaft (past the carrier/center bearing, rear end side) where it slides on it seems to not be on the spines all the way. I can push it up and down like it's barely on the splines. I don't know if this is normal and that is just play, or if it's too short. It seems like as the rear end goes up and down the shaft would need to move in and out, but it seems like it's barely on there to begin with. Maybe some of you can take a peak under your truck? Any advice is appreciated. This is stock suspension by the way.
Keepin It Real
07-24-2007 02:19 PM
