04-08 Super Duty Firewall differences (for dash swap)
#766
I haven't had any major breakthroughs unfortunately. Life seems to be taking over and i am finding myself without a lot of time to get this project complete...student loans suck (not mine, my wife's lol mine are cheap). Working for the house and to pay off our outrageous student loan debt so the truck is taking the back seat but my expedition is starting to get tired and worn out so i think the truck will end up being my focus this spring/summer in the event my expedition decides to take the same route my F150 did..R.I.P.
If you have any questions up until I basically stopped though i can assist, I lurk on here almost daily still just haven't made progress to post. I also found my Ford CD so i can pull diagrams again up until the 08 model year.
#767
Column.
i marked the shift cable in part position, cut the shift cable mount off of my 02 column and welded it in place on the 08 column, same location just opposit side of the 02. use your marked cable for spacing.
for electronics, wiring is posted earlier in this post, i forget where. just connect wires how they are labeled and match them.
wipers are wire to wire control wise and work great. hazards on the 02 are switched, and momentary pulse on the 08.
you can use 5 relays in a impulse latched setup.
Cruise wires correlate also. but resistances are different in the controls so they will not work.
shift interlock is wire to wire, there was confusion on 1 wire from park input on 08, connect it to the 12v wire on 02.
air bag wires same.
i used 5 relays for lights and 5 for ignition
all relays are powered, and groundsncontrolled theough ignition and multifunction
You will power the relays for accy, run, run, run strt, and start. and ground them through the ignition switch.
the 02 column uses contacts to control power flow, so just match wires up and connect to relays.
there are 5 power and 5 outputs. 1 for each listed above.
the 5 other relays for lights,
power in out from headlight switch. to multifunction
high, flash to pass and 1 for each turn signal.
i bought relays with base from amazon.
50$worth.
ill see if i can find my schematic i drew up,
air bag wires same.
50$worth.
#769
#771
#772
Yea, I know what you mean. I’ve got 90% of the parts to do the swap. Got most of the ‘07 F-150 headlight switch wiring figured out. The terminals are the same if anyone is curious, as are the colors for the most part.
I’m thinking the 08 gauge stepper motors will work with the older electronics, but I still need to confirm that when I pull the dash apart. Thinking about trying to leave the gauges on the board, soldering wires from the old board to drive them, and just cutting the existing traces. Also gonna try to leave power to the 08 board led’s for illumination, soldering wires to the dummy lights and cutting the existing traces to those as well.
Frank
Frank
#773
Expedition center console and getting the shifter to work
monte how did you get the center console shifter to work in the expedition console I used the newer 15-16 expedition center and have it in I’m curious how you did it and what cable you used I’m guessing I would have to get a different shift cause the one that’s on the newer console is electronic no cable
#774
#775
So question I have is.....
Ok. So I'll have some huge updates soon. So far everything in my truck works minus, the cruise control, hazards, and my right blinker (only when brake is applied, no blink just "buzz" sound from column). I used a trailer brake converter to get around the dual filament bulbs, because I have aftermarket LEDs for taillights. So if anyone can help me figure it out just let me know. I think I may have a bad converter. I'll try swapping tomorrow. Also I have center console shifter installed and working flawlessly.
so if I used the both fuse boxes from 2012 would all my body stuff work?
I would use the original fuse box and pcm to run my engine and transmission. Any help would be great.
I started out as like a full interior swap. But that seems like more work if I have the complete body and wiring for it.
#778
These guys now have conversion kits for the dash and front end... they have several videos on Youtube..
https://mcnastycustomz.com/store?olsPage=products
06silvercrew
Ford Truck Parts for Sale
03-02-2012 03:56 PM
