04-08 Super Duty Firewall differences (for dash swap)
#61
Just so you guys know I am still working on this slowly, I just recently rekeyed the ignition cylinder to my current key so I wont need to get a second key or change my locks. I just got a new cylinder off ebay for $25 that came with all the little pieces to construct it.
Also I fixed some photo bucket issues and ill get my pictures back up.
#63
Most current Dash photo minus glove box:
Once I get my car to commute to school in I will be starting to really roll and make progress on this project. Right now my truck is my commuter and along with sucking my wallet dry commuting 50+ miles a day I don't have much time after school where I have usable light outside yet.
#64
#66
#68
I am not trying to take over your post. I just wanted to let know the areas i had trouble with so your project cpuld gp smoother. The problem I encountered was the ductwork for the venting. The firewall hvac unit on my 04 was to the right of 08 dash. For the defrost vent I went and picked up a 18" metal brake for 20 bucks and went to home depot and picked up 16" joist enclosure tin for heating and made a duct. 1 3/4" X 6 1/4" X 16" wide. It fit like glove and it did not affect the airflow. I have to admit that was a huge concern for me. But it never seemed to affect it at all. AS for the front ducting I actually moved over and had to fabricate that with a combination of the exsisting ducting and some 4 " tin elbows from homedepot. I have a couple pice I could post once I figure to how todo it.
#70
#71
#72
#73
#75
Thanks. If you see the tin duct that is on defrost vent it is 2"deep. That is why it is so ugly. The second time around was perfect. LOL. I wish I would have documented this better And had more pics to share. I originally was going to use the 08 cluster however that is a bigger undertaking than I first guessed it would be. I think that will be next winters project along with the steering column. The downside by using the 04 cluster and the 08 cluster lens shields the idiot lights on either side. I am not sure what I am going to do about it yet .
