56 F100 gas tank troubles
Old 09-23-2013, 02:50 PM
ZSK's Avatar
ZSK
ZSK is offline
ZSK has a very good reputation on FTE.ZSK has a very good reputation on FTE.ZSK has a very good reputation on FTE.
Recently brought my F100 out of a 10 year hibernation. My parents made a visit to Jacksonville,FL from Michigan and brought the truck with them.
After unloading the truck my dad and I had it back up and running in short order. Enough to take it up and down the street in front of the house. It sat for a week or so, and now it isn't getting fuel to the carb. I have a frame mounted electric pump that runs but doesn't seem to push fuel. Simple right? I think some sediment has clogged the pump...working on that seperately.
What is rather bothering to me, is that when disconnecting the lines to the pump, the inlet line (outlet from the gas tank) pours out fuel. It'll keep running out until plugging or clamping the line off.
What is causing this? The tank has a top outlet which has me confused why fuel would continue to flow out of the tank.
I have a long list of maintenance items to take care of, but here's an as it sits picture.
Old 09-23-2013, 03:07 PM
Normalbloke
Normalbloke is offline
Normalbloke has a good reputation on FTE.Normalbloke has a good reputation on FTE.Normalbloke has a good reputation on FTE.
Siphon effect....
Old 09-23-2013, 03:12 PM
ohbrian
ohbrian is offline
ohbrian is starting off with a positive reputation.
Yup it's siphoning. There is still a rubber line that goes to the bottom of the tank and that is STILL above the level of the line to your fuel pump. If you can get that hose above the bottom of your tank it will stop.
Old 09-23-2013, 03:40 PM
ZSK's Avatar
ZSK
ZSK is offline
So simple, I'm embarrased that it escaped me.
Old 09-23-2013, 03:48 PM
Normalbloke
It'll only stop when it's raised above the level of the fuel in the tank, not the tank bottom itself!
Old 09-23-2013, 04:25 PM
ohbrian
ohbrian is offline
Yeah what you said I should know this since I spent yesterday covered in gasoline as I replaced my tank hahaha.
Old 09-23-2013, 07:28 PM
53FOPAR's Avatar
53FOPAR
53FOPAR is offline
53FOPAR has a good reputation on FTE.53FOPAR has a good reputation on FTE.
Nice looking truck by the way. Stock Y block?
Old 09-23-2013, 09:29 PM
ZSK's Avatar
ZSK
ZSK is offline
Lincoln 317
Old 09-23-2013, 11:14 PM
smallello's Avatar
smallello
smallello is offline
smallello has a great reputation on FTE.smallello has a great reputation on FTE.smallello has a great reputation on FTE.smallello has a great reputation on FTE.smallello has a great reputation on FTE.
Ah, covered in gasoline... Nothing like it!
Welcome to the hobby!
Old 09-23-2013, 11:19 PM
ohbrian
ohbrian is offline
Wow that is nice!
Old 09-24-2013, 08:11 AM
AXracer's Avatar
AXracer
AXracer is offline
AXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud of
Welcome, nice truck!
Binkowski
25
08-05-2015 09:28 PM
85camaroman
03-10-2015 04:47 PM
foofees
10-02-2014 09:18 PM
pickenspolitics
18
05-31-2014 09:15 PM
reed1951
24
09-23-2013 02:57 PM
Quick Reply: 56 F100 gas tank troubles
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
