does anyone have a part number as well as a manufacturer for polyurethane bushings to fit a 2" lift skyjacker soft ride rear spring for a 1978 ford f250 ? everything i find is for a stock spring, skyjacker says that they use stock oem sizes but i cant find anything that fits the front portion of the rear spring ans skyjacker only sells the rubber bushings. winter is getting close and i'm running out of time. any help is appreciated. thank you/
Can't supply any dedicated part numbers but Prothane and Energy Suspension have listings for generic bushings, you simply match existing size with one of those listed.
Hard to believe someone doesn't have something that would work.
thanks, called skyjacker , they gave me part numbers for rubber bushings. asked why if they use oem sizes then why doesnt anything fit. the guy just said " i dont know " got a list from energy, just have to clean and mic my spring and go from there i guess.
Suspension Restoration Parts Co., these guys have just about every bushing known to man. found exactly what i was looking for. guy on the phone was very personable and very professional. defiantly will be using them for now on.
