2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Spark plugs
Old 09-21-2013, 09:33 PM
Boomer1956's Avatar
Boomer1956
Boomer1956 is offline
Spark plugs
2007 El Limited, 81K. I am very capable of doing mechanical work. Brakes, ball joints, tie rod ends, o2 sensors, window regulator to name a few. I am very concerned about all the messages about these 5.4's and the spark plug issues. I am considering taking it to my dealer and letting them change the plugs. Any questions I should be asking and about what price can I expect.
Old 09-21-2013, 10:50 PM
Boston Mark's Avatar
Boston Mark
Boston Mark is offline
I've heard the engine has to be COLD COLD COLD!
Like room tempeture cold.
Old 09-22-2013, 07:56 AM
thinksnow's Avatar
thinksnow
thinksnow is offline
I reluctantly did it myself figuring if one breaks I will by the removal tool and go from there. I followed the procedure I found on this site, someone had posted a video link.
-first I did a seafoam induction hot bake.
-using my shop vac and some down sized tubing I picked up from HD I vacuumed all the dirt/sand that finds its way down by the spark plug. You will be surprised at whats down there. You certainly don't want that debris falling down into the cylinder.
-next using a ratchet I gave each plug a 1/4 to 1/2 turn followed by a good dose of PB blaster. Then I let it sit for 2 hours
-from there I used a mini electric impact wrench. The smallest one I could find as space is tight. It certainly took some fanageling on some of the plugs.
Every plug came out without a problem.
Bosch Bare-Tool PS41B 12-Volt Max Lithium-Ion 1/4-Inch Hex Impact Driver - Amazon.com Bosch Bare-Tool PS41B 12-Volt Max Lithium-Ion 1/4-Inch Hex Impact Driver - Amazon.com
Old 09-22-2013, 04:33 PM
Boston Mark
That IS good news! I'm really glad you took UR time and all went well.
What did the old ones look like? Did You dress the new plugs for next time?
Old 09-22-2013, 04:53 PM
thinksnow's Avatar
thinksnow
I put anti seize all the way up the threads and neck of the new plugs. I have a pic of the old ones but for the life of me cannot figure out how to upload it.
Old 09-22-2013, 05:58 PM
clarky03's Avatar
clarky03
clarky03 is offline
That's some good info there.ill have to keep that in mind
2046fan
1983 - 2012 Ranger & B-Series
02-10-2018 12:32 AM
makuloco2000
11-20-2013 08:43 PM
Ed
06-14-2011 08:49 PM
lasmacgod
Modular V10 (6.8l)
08-23-2010 04:15 PM
dassmoof
1978 - 1996 Big Bronco
02-12-2003 06:03 PM
Quick Reply: Spark plugs
