89 f150 302 wont run
Ok my truck used to start up idle high but run fine until it idled down then it spits and sputters and kills itself it seems to be running rich and now it won't crank over its an 89 302 with an 88 302 ecm replaced starter solenoid alternator battery fuel filter fuel pressure regulator plugs wires ignition coil and idle air control valve but haven't got to check if that fixed the idle problem do to starting issue plzz help and thanks in advance
Joshua Adrian
03-20-2018 02:21 AM
Tmaxx35
01-04-2015 10:38 AM
Wilber15
13
07-16-2008 09:19 PM
OneFine69
06-28-2005 09:01 PM
