2nd test drive didn't go well so now I need Help
First, here is a before photo and an after photo.
I took the truck out for a 2nd test drive after I put new tires on. I parked it and had lunch, before I was going to take it to get the exhaust installed. When I put it in reverse it would not move. As I let out the clutch it acted like the brakes were locked. It would move forwards. I end up pulling it backwards with a tractor and driving it into my shop.
Is there anything I should check before I need to rebuild or replace the trans? If the trans is not an easy fix I think I'll put in an Automatic. Or an updated trans with overdrive.
If that's the case I will be asking what autotrans will work with my 223 engine.
pb0000
03-01-2019 06:34 PM
Bergerson
05-31-2010 10:49 PM
just-n-time
04-28-2009 11:53 AM
bountyhunterjp
04-20-2006 01:56 AM
FireHazard
06-28-2003 03:53 PM
