Newbie 85 f250 frame off resto (Image Heavy)
#154
#157
No burr's, smooth as can be. I do see something of concern on the outside of the stub, not keeping it out, but there's a groove in the stub of the balancer. We'll call this line "L1". The old seal must have ground a groove, so I'm sure the new seal will leak. But looking at where the groove is in relation to the thickness of the seal it doesn't look like the HB was in any further then it goes in right now. Unless this groove is there on all stock HB's.
In this pic you can see where the outside of the seal sits on the stub right now. "L2"
.......and where it "should" sit "L3"
Does anyone else see the difference in the shine of the metal between L1 & L2 and then L2 & L3? If that makes sense. It looks to me that L2 to L3 was exposed and wasn't in the timing cover.
#158
#159
#161
Originally Posted by FordFETruck
The key isn't hard to get back in, it's harder to get out than in. Just tap it back in with a ball pein hammer.
#162
Personally I'd say to hell with that balancer install tool and just use the bolt for it and a breaker bar! I'll bet you it'll go right in and seat fully. I've done mine that way three times and it's worked flawlessly every time. Use a light penetrating oil on the shaft and inside the balancer.
#163
#164
#165
A few things come to mind as the culprits
1. I changed the timing set, the crank gear could be thicker and therefore keeping the HB out that extra thickness.
If you measure from the timing gear to the end of the crank snout, it's 2". If you measure from where the inside edge of the HB( where it " should" sit flush to the crank snout) to the end of the stub it's 2 1/8". So maybe that's why the balancer is out 1/8" from the crank snout and not flush.
2. Water pump has been changed, but the measurement from the back to the front of each pump is within 1/32 of an inch.
3. When I took the water pump off the timing cover originally I don't know if there was a paper gasket( 1/16" maybe) between them. I know for a fact there was no paper gasket in between the timing cover and the block( another 1/16").
So with the two gaskets and the discrepancy of the 1/32" between the old water pump and the new you get maybe a 1/8"+ of stuff holding the water pump out further.
Now...... when I looked under the ring of assembly oil on L2 there is a groove there also. So it seems like the seal is in the exact same place on the HB that it was pre-build.
Are we confused yet?
