1978 - 1996 Big Bronco
View Poll Results: Which transmission
NP435
70.00%
ZF5
30.00%
Voters: 10. You may not vote on this poll
NP435 or ZF5 in a 78-79 Bronco
Old 09-15-2013, 05:18 PM
ManfredVonRichtofen's Avatar
ManfredVonRichtofen
ManfredVonRichtofen is offline
ManfredVonRichtofen has a great reputation on FTE.ManfredVonRichtofen has a great reputation on FTE.ManfredVonRichtofen has a great reputation on FTE.ManfredVonRichtofen has a great reputation on FTE.ManfredVonRichtofen has a great reputation on FTE.
Ok. I was debating on which to swap in my C6 79 (466 engine) Bronco. I was choosing the ZF5 since I will use this Bronco to drive on the highways BUT I would also go off-road with it. Nothing to wild. I'm hoping the ZF5 would get better MPG for my 466 since the RPM would be lower at higher speeds.
Which would be better?
-The NP435 will have the lowest first gear.
-The ZF5 will have the OD 5th gear but also a low first, but not as low as the first in the NP435.
-The NP435 is known to be bulletproof.
-The ZF5 is known to be ok for moderate stuff but the casing of the transmission is weak.
-The NP435 will be a simpler swap in the 79 Bronco.
-The ZF5 will require some modifications.
-The NP435 could handle the NP205 transfer case.
-The ZF5 would have to have the NP205 to have some braces due to the heaviness of the NP205. The Borg-Warner transfer case wouldn't and would have a lower gear in and be light BUT the NP205 could get lower gears in it.
Which would you do?
I'm wanting to determine before I do the swap. I'm thinking about the ZF5 and save the NP435 for my 79 F150 4X4. Let's see what yall have to say.
Old 09-15-2013, 05:26 PM
gatorfor88's Avatar
gatorfor88
gatorfor88 is offline
gatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputation
Personally I would always choose the strength of the 435 and the 205 over any combo. You can always change gearing if needed but its harder to build in strength. When in doubt go stout.
Old 09-16-2013, 03:27 PM
GruesomeJeans's Avatar
GruesomeJeans
GruesomeJeans is offline
GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.
Now I thought the ZF was claimed to be bulletproof? maybe the aluminum case ones weren't as strong? But I though that the Cast Iron ones were nearly bulletproof. I think I'd personally still go with a ZF but I've never worked with either and never heard of the BG one.
Old 09-16-2013, 04:35 PM
Encho's Avatar
Encho
Encho is offline
The Southernmost Mod
Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.
You made a good case for the NP435 Manfred, so I voted for that one, simplicity is key to this swap, and reliability is always a +. For my truck I would pick the ZF5 without a second guess, but mine is from the 92-96 gen.
Old 09-16-2013, 05:21 PM
ManfredVonRichtofen
Yeah, I was thinking about the NP435. I'm still kinda leaning to the ZF5 since I still have it. Let's see if more people can change my mind or keep me on the ZF5.
I liked the ZF5 that was in my 1990 Bronco but I don't know how good it will handle a 466....
Old 09-16-2013, 05:33 PM
gatorfor88's Avatar
gatorfor88
These transmissions aren't particularly strong. Only Rated to 420 ft/lbs of torque (for the common s5-42), some are rated to 470 ft/lbs (s5-47, only 2 yrs production though and maybe only behind diesels but bell can be drilled to mount to 460). I dont know what kind of torque the Borg Warner was designed for but it was never meant to be behind a big block
Last edited by Encho; 09-16-2013 at 08:29 PM. Reason: fixed that double post for you bud ;-)
Old 09-16-2013, 05:40 PM
ManfredVonRichtofen
Well I got to finish rebuilding the NP435. I have a 351m/400 Flywheel which should work. All I would need to do is:
Finish rebuilding the NP435
Get the crossmember for the NP435
Get the driveshaft for the NP435
Get the motor mount for the NP435
The reason why I was thinking about the ZF5 was because I would travel on the highways usually and I plan to keep this Bronco.
I don't know the MPG differences I would get between the ZF5 and NP435.
landshark99
131
08-02-2018 10:28 AM
Hank351
09-08-2016 09:12 AM
SDDL-UP
09-07-2015 09:06 AM
Ken2600
06-26-2014 03:45 PM
F-250 WARHORSE
Engine Swaps
10-10-2013 10:31 AM
Quick Reply: NP435 or ZF5 in a 78-79 Bronco
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
