NASA I think we have a problem.
My truck is cranking way too long before it starts. The last three times I started it cranked for about 10 seconds, then I would cycle it again and crank it for about 5 seconds before it finally starts. I'm thinking it might be time to check the FICM. To give you a little back ground, I straight piped my truck about a year ago. Shortly afterward I noticed my truck was cranking over longer then usual before starting, coincidence? First thing I checked was the FICM voltage which was fine. So I've been driving without a problem since the. Now as of today it's taking much much longer to finally start. I will put a meter on the FICM tomorrow. Any other thoughts or ideas?
NOT Bad
Valve Cover comes off and Oil Rail on top inject comes out
The Standpipe feeds the Oil Rail and you will also change 1 plug each Rail
Standpipes and Dummey Plugs are done together
Same work to Get them BOTH Changed out and Price of Parts is OK
The SAD Part is Only Repair Shops Tend to Only change 1 at a Time
this is where they "Bad Shops" like to Screw them All the Labor to keep going in
But the Bottom Line right Now is For you to get a Gauge so the truck can be Tested
Throwing parts will be spendy unless there is a Plan
The Gauge will let you see the Bulk amount of the S#!) so its Fast and Saves money
At Advance Auto the Promo Code TRT30 still works (so does DOW32) to get a scangaugeII for $112.....
https://www.ford-trucks.com/forums/1...ance-auto.html
Well I finally got my SGII set up and on the truck. The FICM volts checked out, the injector pressure stayed up above 500 (hot start). Still doesn't explain the hard starts. Is there something else I should be checking? The good news s my oil cooler appears healthy for now. Once I was all set up correctly I went for a ride . Initially the temps stayed within 0 to 2 degrees of each other. After a WOT run up to 90mph they split by 6 degrees, 194 & 188. It pretty much stayed there from that point on. I guess I don't have an oil cooler problem (yet).
powerstrokedieselboy
08-03-2014 04:18 PM
