Offroad & 4x4
F100 wheeler build
Old 11-02-2013, 05:03 PM
alpha/omega's Avatar
alpha/omega
alpha/omega is offline
I'll put my welds with my .035" 75/25% miller 220v mig against any one on this board in 4wd related applications. Can't say with any confidence about xray or pressure stuff but I'm sure I'd do decent at minimum
  #47
Old 11-02-2013, 05:56 PM
73 ford guy's Avatar
73 ford guy
73 ford guy is offline
Too bad there's only a few that are actually on this board! Lol
For the most part .035 hardwire on a wheeler is totally fine. For heavier plate you can also setup your machine to spray transfer mode. It's not a setting on the machine it's basically just hard wire with about 27 volts and lots of wire speed, probably around 400.
Welding will have less of a crackling sound and have more or a quieter humm.
If you've never heard of spray transfer setting read here. How to Mig Using Spray Transfer - Mig Welding Settings for Spray and Short Circuit
You will only be able to weld flat and horizontal as your puddle is too hot. Out of those positions with heavy steel is where again flux core has the advantage. That big dirty pipe pic I posted you couldn't do in spray transfer setting. A bottle with more argon percentage is reccomended they say but I've still used a 75/25
  #48
Old 11-02-2013, 06:09 PM
tjc transport's Avatar
tjc transport
tjc transport is offline
i ain't rite
Received 3,102 Likes on 2,164 Posts
i trust the welds from my lincoln 215 power mig, but for anything structural, i still use the miller blue star stick welder.
  #49
Old 11-03-2013, 07:13 AM
77mud's Avatar
77mud
77mud is offline
I'm not gonna say I'm the best welder. an I'm definitely not got to best looking welds but I've not had one fail. from welding spring hangers under trailers to other odds an ends. I've had a set of hangers break but never at the welds.
  #50
Old 11-03-2013, 12:33 PM
kjett's Avatar
kjett
kjett is offline
Not going for looks either, but I'll put my little Lincoln SP-135 mig and me behind it against any 4wd related weld job! I've snapped plenty of tube and plate but not any of the welds.
  #51
Old 11-03-2013, 01:13 PM
alpha/omega
^^^^Except when welding a nut on bolts sheered below the threaded portion of a sterling yoke. You leave that to professionals
  #52
Old 11-03-2013, 01:42 PM
73 ford guy
I just extracted broken waterpump bolts by stick welding with a 3/32, 7018 rod new nuts to turn it out. What a pain!! I guess the 5.8 W are known for snapping these
Stick is best when u NEED it to work. Always strong and burns out any grime/grease if its not perfect.
  #53
Old 11-03-2013, 01:46 PM
73 ford guy
  #54
Old 11-03-2013, 01:54 PM
alpha/omega
This may be true with 6010/6011 rods but certainly not 7018
  #55
Old 11-03-2013, 01:59 PM
73 ford guy
  #56
Old 11-03-2013, 02:00 PM
73 ford guy
^ farmers rod. Lol
Yeah they're good for that too. I used hardwire to weld my hydro assist fittings on box and it leaked pin holes. I ground it out and used a 7018 to burn it out. Problem solved.
O and the 60 rods are 60,000 tensile and snap easier
  #57
Old 11-03-2013, 02:35 PM
lucky_thirteen's Avatar
lucky_thirteen
lucky_thirteen is offline
I'm just confused why the ram tabs have plate doubled then welded. Is it you just like to sit at a bench to weld more? I'd just of gone with thicker plate.I'm confused why it bothers you so much. There's lap plates all over the truck. You seem to like to replace all your sheet metal when you get a dent, what's the big deal if I put some extra welding time in? Not a big fan of the weave weld, and I prefer using flux core wire for better strength. I don't weave, flux core is gay, and if I was worried about a lack of strength I would tig weld it all Alot seems like overkill like the shock brace now over motor. What is overkill about that? Overkill is a funny word coming from a guy with 16' of lift, an innie and outie cage, and jib cranes. Link tabs look like 1/4" steel. 3/8 or 5/16 would be much more beef. So is it overkill or is it not beefy enough? They're 3/16 with 1/8 welded on. Of course thicker steel would be more beef, it would also be more overkill which seems to chaff your nuts
Nice looking pieces and fit up though. Plans to paint or u just gonna let er all rust? It will be painted
How thick is the diff over? flange section looks like 1/8 or 3/16. I'm guessing its on old cover,flange section?It's all 3/16, no old diff covers involved
zero poops have been given pirateflippie
  #58
Old 11-03-2013, 02:53 PM
hav24wheel's Avatar
hav24wheel
hav24wheel is offline
How about exhaust manifold bolts 3 or so threads below the aluminum head.......
lucky 13, it all looks plenty strong to me, who cares if you have multi layers vs one thicker chunk.... I've done **** both ways, and both work fine.
  #59
Old 11-03-2013, 03:01 PM
kjett's Avatar
kjett
kjett is offline
I love how he gives 73 grief
  #60
73 ford guy
^Flux core is gay...... Ok...!!
Obviously lack of knowledge there. I don't need to get into any arguments here. I'm a steel fitter,welder for a living and there's nothing you can teach me this I know 100%.
Quick Reply: F100 wheeler build
