The scent of antifreeze under the hood after driving.
Ive always had the scent of antifreeze after driving does anyone have this issue it doesn't leak or burn coolant but i just always had this issue even before the rebuild does anyone else have this problem?
It could be something as simple as a loose hose clamp or an old radiator cap. Look at your overflow tank and check for a split hose, missing cap or crack in the plastic housing. Look for green residue.
Are you using a heating manifold under an Offy intake? If so, wipe your finger around the fittings after you run it and see if they are 'sweating' fluid.
Yes I do have it under the manifold but I haven't hooked up the hoses yet.
Check for discoloration or what looks like calcium buildup around the water pump. It could be that under pressure your system is spraying a fine mist of antifreeze/coolant. Possibly not enough to puddle or even drip. But you would smell it. Good Luck.
I had the same problem a year ago, and this was my problem. I couldn't track it down until one day I happened to pop the hood while the truck was warm and running, and noticed just a bit of dampness where one of my hoses left the water pump. It wasn't enough to really lower the coolant level, but was still enough to smell.
