Cv shaft or 4x4 issue?
Hey guys back again. I just replaced my drivers side wheel bearing that was squealing pretty bad. After replacing it I now have the same noise only consistent where before it was only when I turned the wheel to the right. I noticed the teeth in the cv shaft where a little warn down when I changed the hub. Now also along with that noise I'm getting a clunking sound. Should I just change the cv shaft for $79 or is there something else I need to be looking at?
Johnwb150
12-07-2014 08:00 PM
