Issues with Red Head boxes or not? A discussion
#77
I am happy with my new one (warranty) my steering it tight now. That being said I did have one failure so I can't say if it was just a fluke or a problem until I put some miles and abuse on this one and see if it holds up. I about ran over the curb on my first test drive after install because sheesh the truck turned when I moved the steering wheel.
#79
on
#80
OH yea? That's where I got the one I have now and the output shaft bushing / bearing is completely gone. Don't want to repeat that. This truck only sees about 500 miles a year, it's not like this box has a lot on it now. Lifetime warranty is great if you don't mind replacing it for a lifetime. I like one and done...
#81
on
#83
#84
I got my core back today on my warranty replacement and also got the email Harvey had promised. Now take it for what's it worth but at least he did send me a note on what they found.
<!--[if gte mso 9]><xml> <o:OfficeDocumentSettings> <o:AllowPNG/> </o:OfficeDocumentSettings> </xml><![endif]--> In your case, there was a pin in the valve that came loose. That's what was causing the play.
Thanks,
Harvey
Thanks,
Harvey
#86
As a matter of fact:
https://www.ford-trucks.com/forums/1...rebuild-2.html
I personally wouldn't want anything in my cooler lines that could block up and stop flow.
#88
#89
#90
