Power Steering Pressure Switch
Old Sep 6, 2013 | 12:24 AM
diamondjranch's Avatar
diamondjranch
Hey guys, I'm not normally in this forum, but one of my delivery trucks is puking fluid out of the pressure switch. The problem is, I can't seem to find one ANYWHERE!!!!! Dealers say obsolete, and the ford parts site concurs. Haven't found one in the aftermarket, either. We'd rather get a new one if possible, but if we have to go to the salvage yard, so be it. If anyone knows where I can get a new p/s pressure switch for an 04 Ranger 2.3, please let me know ASAP. Thanks.
Old Sep 6, 2013 | 03:12 AM
michigan66's Avatar
michigan66
LMC Truck lists a power steering switch for 83 to 01 Rangers. Check the picture of the switch. It may fit your 04 truck.
Old Sep 6, 2013 | 07:51 AM
tomw's Avatar
tomw
If you can't get a switch, you can just plug the opening. It is a signal to the computer that the power steering pump is about to add some load, so bump the IAC to prevent stalling and shaky idle. Most times it is not needed, just a convenience.
I do not believe it will set a code, or rather turn on the CEL, in normal circumstances. It will set a code if you run the KOER test with EEC-IV, as you are told to wiggle the steering wheel within a time frame after getting a specific beep or light signal, along with stepping on the brake pedal and going WOT and back to idle {quickly!!}.
My guess is that the switch was used in a lot of different models. The same switch might have even been used in the rack and pinion systems, or full-size trucks & cars using a steering box vs rack & pinion.
tom
Old Sep 6, 2013 | 10:06 AM
pawpaw's Avatar
pawpaw
NAPA shows two P/S pressure switches for Rangers up through 03 that look the same, one for $24 the other for $29, looks like a call to the salvage yard might be worth the time.
Old Sep 6, 2013 | 11:42 AM
tomw's Avatar
tomw
Replacement hoses from rockauto . com:
EDELMANN Part # 80346
GATES Part # 357480
Dang, they're good prices...
And switches, maybe what you need here:
Ford Power Steering Pressure Switch | Auto Parts Warehouse | Free Shipping
Lotsa good pictures ... may you find what you need.
tom
tmcalavy
Jul 13, 2023 10:28 AM
hreyesg
Jan 8, 2019 07:10 AM
Vanhecht
Sep 16, 2016 11:58 AM
DSinOR
Apr 25, 2007 04:47 PM
Jrock909
Jan 8, 2005 05:29 PM
