GOOD INFO TO HAVE, WISH I HAD
Many moons ago I built a gas tank with every intention of doing it right. Well everything was right until I put gas in it and tried to drive the truck. What I, after all these years, didn't know was that the clear protective coat on that brand new sheet of steel was gasoline soluble. After about 50 miles of otherwise trouble free driving the thing didn't want to idle and before I could get home it quit. I must have been living somewhat right that day because as I sat on the side of the road, with a clogged fuel line, a guy happened by in a golf cart and he just happened to have an air tank with 60 lbs of air in it. Five minutes later I had a clear fuel line and made my way home. The cure for the problem was to put 10 gallons of vinegar in the tank and turn it about every 12 hours. After this loosened up the remaining crap I drilled a hole in the tank and drained it. I then attached a length of steel brake line to my air hose, reached in through the filler necks and the hole for the sending unit and blew air and new vinegar through it til it was clear and dry. Welded up the hole, put in a new fuel filter and it runs like a champ. Sure would have been nice to know about that clear coat BEFORE I made the tank. Hope this comedy of errors helps somebody. Later
kobaltblue
11-04-2012 02:47 PM
Vegas123
18
05-24-2012 11:13 AM
1994F2507.3L
06-19-2011 09:44 PM
fishindave11
13
06-25-2007 12:18 AM
martinb
13
10-29-2002 02:43 AM
