2000 f250 wont start, starts then dies need help
My truck will turn over very strong but will not crank. it cranked one time then died immediatly. 30 min later it cranked and ran for about 5 min then died again. any ideas, alternator, fuel pump.
gas v10 motor, full of gas, new spark plugs.
If it was the alternator, it probably wouldn't start. I would start with the fuel system. Filter, clean the IAC valve, then off to the pump.
Mine did something similar right after I got it, although it wouldn't run. It would crank and TRY to start, but wouldn't. It was the fuel pump.
Good Luck!
Good Luck!
Good Luck!
Good Luck!
jjkoontz
Modular V10 (6.8l)
22
08-15-2019 09:55 AM
