1978 - 1996 Big Bronco
Ford 1996 Bronco Starter Questions
Old 08-30-2013, 03:23 PM
robjs111
robjs111 is offline
robjs111 is starting off with a positive reputation.
having issues deciphering what is the battery terminal connection on starter pictured below.
Thanks.
1996 bronco
351w
Edit
Starter does not have a mounted solenoid , have to use a firewall mounted version.......................
Old 08-30-2013, 04:46 PM
robjs111
robjs111 is offline
Possible to install a firewall mounted solenoid and if so how?
Old 08-30-2013, 10:41 PM
GruesomeJeans's Avatar
GruesomeJeans
GruesomeJeans is offline
GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.
Hmm If I'm not mistaken this should be it right??
I mean to me that looks like it's it, and maybe you use one of the other 2 for a ground? Jeeze it's been a while since I did mine, I forget how it's wired up
Old 08-30-2013, 11:57 PM
Torky2
Torky2 is offline
Torky2 has a great reputation on FTE.Torky2 has a great reputation on FTE.Torky2 has a great reputation on FTE.Torky2 has a great reputation on FTE.
Oh-boy! Isn't somebody from 1970 going to want their starter back?
That looks like an old Positive-Engagement starter from yesteryear, as found on small-block Fords. 460's got a Solenoid-Actuated starter instead, as did your Bronco of the 90's.
Is this for some non-Bronco project? OK if it is, but tell us first
There is only one electrical connection to a P-E starter. Some had it on the end-cap as the one in your pic, most had it on a post that stuck out through the side of the starter.
Then need a starter relay that was made to take the current of the starter.
EDIT - Didn't the 351 Cleveland take a starter like that? Will it even properly mount and engage on a trans behind a Windsor? I sure don't know.
Old 08-31-2013, 12:13 AM
GruesomeJeans
351Mutant does, the C and W probably did as well. I was a bit confused but I've never seen a starter besides my own stuff.
Google gave me this as a 96 starter.... Yikes!
Old 08-31-2013, 08:32 AM
Nighteyez's Avatar
Nighteyez
Nighteyez is offline
Nighteyez has a superb reputationNighteyez has a superb reputationNighteyez has a superb reputationNighteyez has a superb reputationNighteyez has a superb reputationNighteyez has a superb reputationNighteyez has a superb reputationNighteyez has a superb reputationNighteyez has a superb reputationNighteyez has a superb reputationNighteyez has a superb reputation
I have a 93, and have two solenoids, one on the passenger side fender, and another on the starter itself. Interesting that a 96 would only have one.
Jim
Old 08-31-2013, 11:08 AM
robjs111
robjs111 is offline
Let me clarify my original statement.
The aformentioned starter is an aftermarket piece that came with a ford crate motor that I purcased for my 96 bronco. Also have since learned that my 96 bronco has 2 solenoids one on the starter as well as one located on fenderwell next to battery. The starter in question does not have a mounted solenoid so can I use starter on bronco or do I have to add another solenoid?? Or would it be easier just to buy a stock oem replacement starter?
Thanks.
Old 08-31-2013, 11:27 AM
Nighteyez's Avatar
Nighteyez
I would buy a oem replacement starter, but that is just me.
Jim
robjs111
Ford Truck Parts for Sale
05-21-2015 09:41 AM
robjs111
09-26-2012 01:36 PM
robjs111
WTB - Parts & other
08-01-2012 11:58 PM
robjs111
04-02-2012 01:19 PM
robjs111
04-08-2007 07:40 PM
Quick Reply: Ford 1996 Bronco Starter Questions
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
