ZF into 79
Old 09-13-2013, 09:25 PM
bpete's Avatar
bpete
bpete is offline
ZF into 79
I am planning on swapping a ZF into my 79 F 350 2wd. It appears to me a ZF has a 1.25" 10 spline input and my old T18 has a 1.0625 10 spline input. The late 80's pu's with a ZF have a 12" clutch and I have a 11" anybody know the correct parts to get the clutch installed???
Old 09-14-2013, 07:36 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,592 Likes on 1,297 Posts
What motor? If you have a 351m/400, there are some issues with the crank stick out that have to be dealt with.
Generally, you would use the pressure plate that fits on your flywheel, and find a clutch disc that fits on the trans. 11" clutch should be OK.
Old 09-14-2013, 09:30 PM
bpete's Avatar
bpete
bpete is offline
Sorry forgot to mention that I am running a 460. Generally, I am quite aware that you would use the pressure plate that fits your flywheel and I am quite aware that many parts people don't like anything other than stock which is why people ask for help on a site such as this. If anyone actually knows and has done this I would appreciate any help as to a pressure plate, clutch disk, pilot bearing and throw out bearing combination I would be quite interested in hearing from them. If you are just going to post to supply some generic information to increase the # of times you have posted most people are not interested.
Old 09-14-2013, 10:09 PM
stuart1's Avatar
stuart1
stuart1 is offline
My aren,t we a wonderful piece of crap.
Old 09-14-2013, 11:11 PM
85e150's Avatar
85e150
Well, I haven't done it, but Ford did, so you should be able to get OEM parts with a simple search.
Your trans DID come from behind a 460 originally, right? If you don't have the trans yet, you should be able to find everything you need in the donor vehicle.
Good luck with your project.
Threads to sift through for first-hand accounts:
https://www.ford-trucks.com/forums/1...er-issues.html
Posts 7 & 12:
https://www.ford-trucks.com/forums/1...ew-to-old.html
70torino429
06-23-2009 01:50 AM
460powerhouse
20
03-03-2006 08:16 PM
JDWIS
09-16-2005 12:39 PM
Mr Man
01-15-2005 09:03 AM
hster
08-30-2004 08:45 PM
Quick Reply: ZF into 79
