Front cab mount 49'
Just remove all 4 of the front cab mounts and jack up the cab slightly, just enough to get the new mounts in. If you haven't removed the front sheet metal you will need to be careful that you don't wrinkle anything.
Also check your frame mount holes. If they have worn it may effect the way your hood closes. Then you will need to weld back in the lost metal.
redf1001962
09-09-2005 08:53 PM
