1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2011 F350 6.7 instrument cluster fault
Old 08-02-2019, 09:14 PM
prwa96's Avatar
prwa96
prwa96 is offline
Does anyone out there know how to get rid of a fault signal on the trip panel please see attached photo.
Cheers Zak
Old 08-05-2019, 05:07 PM
CaptKen's Avatar
CaptKen
CaptKen is offline
Mine did the same a few weeks ago. I’ve tried everything. Hope someone has a clue how to delete it.
Old 08-09-2019, 06:32 PM
prwa96's Avatar
prwa96
prwa96 is offline
Looks like we are the only ones with this fault, lucky us.
Old 08-10-2019, 09:55 AM
saratoga2011's Avatar
saratoga2011
saratoga2011 is offline
It looks like you just have the trip ODO paused. Pressing OK again should un-pause it....taken below from owner's manual.
Trip A/B In this mode, Trip A or B registers the following: • Trip Time — shows the elapsed trip time. This timer will stop when the vehicle is turned off and will restart when the vehicle is restarted. • Trip Distance — shows the accumulated trip distance. • Fuel Used — shows the amount of fuel used for a given trip. • Average MPG (L/100km) — shows the average distance traveled per unit of fuel used for a given trip. • Odometer — shows the vehicle’s total accumulated distance. This value cannot be reset. Press the right arrow key to reach Trip B. Press the left arrow to go back to Trip A. Press OK to pause the Trip A or B screen/press again to un-pause. Press and hold OK to reset the currently displayed trip information.
Old 08-12-2019, 05:45 PM
CaptKen's Avatar
CaptKen
CaptKen is offline
Wish that was it but pushing the OK button does nothing. What happened was I pressed and held the OK button to reset the Trip A. This screen came up saying reset was canceled. I thought it was because I was moving so I waited until I stopped again and pressed OK again. The words saying the reset was canceled disappeared but the big square remained. Trip B works fine.
Old 08-13-2019, 08:17 AM
CaptKen's Avatar
CaptKen
CaptKen is offline
Fixed it!!! Driving to work this morning I got to playing around with it like I have before with no luck. Then I just quickly pushed the OK button and let off for a split second and it went away. Guess I might have been holding it too long before.
Old 09-05-2019, 02:46 AM
prwa96's Avatar
prwa96
prwa96 is offline
Thanks guys I dont know how many times I pressed the reset button but as soon as I gave it one tap it went away. Cheers.
DriverD
12-29-2018 04:21 AM
rtraviator
2017+ Super Duty
09-11-2018 11:16 AM
csoto
03-17-2015 02:00 PM
3broncocrazy
Georgia Chapter
09-17-2007 07:41 PM
66GTO
02-06-2005 10:50 AM
Quick Reply: 2011 F350 6.7 instrument cluster fault
