Engine clean up
Engine clean up
So I decided to order my valve cover gaskets today. Parts store said they would be there in the morning. I went ahead and removed the valve covers, figured I could clean them up with a coat of paint. When I removed the covers I seem alot of sludge. The worst I ever seen actually.
Is there something I can add to the oil to help clean it up. Is it something that has to be ran along time? I currently have a bad radiator in it so it would have to be at idle? Thank you for your help
on
I have used a cheap shop vac to clean up sludge under valve covers. Break it loose with a screwdriver and get it out of there. You dont want it going into the pan and clogging up the pickup screen. I have seen that happen using engine flush liquids. You may be better off to not disturb it.
Auto-Rx Plus Non-Toxic Sludge Remover and Cleaner for Engines and Transmissions
frankenstein f-150
07-29-2009 04:37 AM
