Stock truck build (pics )
#46
So returned home back to the little shop of magic in the back yard & did the job my self . Do not ever use the word " can't " around me . That word does not exist in my vocabulary .
I may need to pull back & secure the bottom right spring as it makes a noticable protrusion in the bottom right front material .Over all I am pleaesd with the out come .
#47
I need to pull back & secure the bottom right front spring as it makes a small noticeable protrusion on the lower RF bottom of the seat base . It has been a ton of work but can see the light at the end of the tunnel .May go out & work on the floor covering of the 1ST-RIDE today .That truck is close to finish also .Would like to install the rear disc brakes after interior is done .When both trucks are done & SS has kicked in ( end of this yr. ) am going to complete the IN-10 -SI-T .The BB Chrysler roadster . May need a lift chair to get into it by that time !
#48
#49
Made some progress wed .aft. It turned into a one man job. The most difficult was lowering the cab on to the chassis around the steering column . Left the column loose so it could hang down some near the dash . It worked fine . Installed the front cab mounting pads & bolts Then the light bulb went off & decided to installed the back dog bones . Good thing I did as the ********* PO didn't get them the correct distance apart when he repaired the cab corners . So thur am going to set the cab the correct distance off the rails & side to side & drill new holes thru the cab arm mntg brackets , weld a small pc of thick wall tubing between them while the dog bones are attached . Was so easy to get side tracked on attaching other items to the cab . Also received a tube of CRL 7708 sealant for the back glass & windshield install .The little woman is going to see her sister Sun - thur . so will have a few days of uninterupted work to do on the stock truck . Plans are to drive it back to the storage garage if the people who said they would show up do .
#50
Fri. progress
Attached the shifting arms , installed the lower door seals ( used an excellant pair of originals ). Had a new set but majority ruled on the original set at the body shop .Installed the door checks , emergency brake cable , speedo cable , test fit the elec. wiper motor & arms ,checked the shifting pattern & every thing works fine , and took inventory .
The truck left the bodyshop & went next door to my buddies cabinet shop .No saw dust sat . Have all day to work on it . Would like to concentrate on the wiring ,or enough to get it fired up & moveable under it's own power . Towing it around is getting old .
#52
sat. progress
Secured the dog bone cab arms & the 4 other mounting points . Installed the 4 pc floor pans & seal .Ran the fuel line & tightened fittings .Installed the right rear corner interior panel so the filler neck could be finally secured . Secured the steering colunm to the dash . Ran some minorwiring . Test fit the abs fire wall cover . Secured the e-brale cable to bell housing . Took inventory again . Installed the elec. wiper assembly which required some minor tweeking of the attaching cage section .Attached the fresh air tube elbow . Secured the trans cover . Plans are for a sun aft. noon - thur . work on the stock truck schedule .
#55
#56
Tues progress . Wed. will be major wiring day , install window regs ,attach the hood to cowl seal , maybe get a battery , and what ever attacelse comes up . Seems one can dssassemble a door in an hour & it takes way longer to assemble just like everything else .Any one know the length & size of the 8 small fine thread screws / bolts that hold the fresh air vent assembly to the cowl ?
#57
#59
Thur progress .Any FTE'er at Truckstock please keep the stock truck on the DL . The little woman thinks it left a yr. ago . Acually it did .It went to the storage garage which is some thing else she doesn't know about .I dread the day when I roll up in the stock truck to take her w/ me to the car show & some thing doesn't look just right to her & it doesn't make as much noise as the BB in the 1ST-RIDE . Oh well , will cross that bridge when the time comes .
#60
Major progress today .
Installed all the wiring tha I could.
Connected the heater hoses .
Wired , connected & installed gauge cluster
Wired & installed headlight switch w/ new **** .
Wired & installed starter button .
Wired & installed ignition switch .
Wired & installed speedo.
Installed dash speaker grill
Insatlled speaker grill trim .
Installed radio .
Fastened steering column to floor mat seal ..
Installed & routed choke cable to carb & secured
Installed throttle cable to carb & secured .
Istalled bench seat .
Took inventory (again )
Am very happy with how this build is progressing .
Installed radio .
